Outbound roule with more than 10 digit prepend
Discussion in '3CX Phone System - General' started by AldoLinares, Jan 10, 2008.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    I can't make this outbound rule.
    What i am trying to do is add there codes so they can speed dial by just pressing a 3 digit code and automatically calls a number that is 12 digit, this was working with the old Panasonic PBX.
    :( its there like a modification on ini or something.
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    If your speed dial is 2 digits then your prepend will add up to 12. If you can make your 2 digits dial work with the rest of your outbound rules.
    Don't strip off any digits either.
  3. AldoLinares
    Nov 12, 2007
    135
    Yea i got some (10) working like that and making the strip on two, but they need like 50 codes my workaround is that but with some codes for like 5 digits and not the 3 that they have.
