outbound routes? codes allowing/disallowing LD?
Discussion in '3CX Phone System - General' started by jjones, May 24, 2007.
  1. jjones
    May 22, 2007
    7
    Does anyone know if there is a way to use codes for allowing or disallowing long-distance usage?
    Thanks,
    Jim
  2. TwigsUSAN
    Jan 31, 2007
    45
    No, at the moment I don't believe there is a way. It would be a good feature to have since I seem to be running into more often these days.
  3. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    Wouldn't it be posible to create a non-existant virtual gateway and then create a rule that directs long distance traffic to this gateway?
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,309
    Yes, it will work.
  5. jjones
    May 22, 2007
    7
    sounds interesting... how would a guy go about trying that?
    Thanks,
    Jim
