Outbound Routing One Account multiple DID's
Discussion in '3CX Phone System - General' started by petewatterschats, Apr 9, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    I have a single SIP account with FlowRoute with two DID numbers. The Trunk Name is “FlowRoute” and the DID’s are 818-111-1111 and 702-111-111. From extension 300 I would like to route it to the 818-111-1111 DID and for extension 400 route it to DID 702-111-1111 but my only option is to route it via the Trunk Name “FlowRoue”, is my only option to have two separate Accounts (Trunks) with a single DID
    10,737
    280
    Have you tried changing the number to be displayed, in each extensions settings to reflect the CID you want sent? I'm assuming that outgoing on either channel is billed to one account and that the DID portion (being able to route by the dialled number to the proper extension) is why you are paying for DIDs
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,335
    75
    If you want to present a different Caller ID when a Ext 300 and 400 call out, you can set the Caller ID each extension present from the Extension Settings of each extension from the "Other" tab.
    It is worth mentioning that although the software will let you write any number in that field, a lot of Providers only allow you to present a number that you own (a DID that you own).
  4. petewatterschats
    Jan 19, 2016
    151
    One SIP Account/Trunk
    Extension Other - I can put a DID I have in the Outbound Caller ID FIELD and using this number the SIP Trunk Provider (FlowRoute) will lookup a caller ID in a CNAM data base and set this value as the caller ID.
    the two DID numbers
    8188823686 CNAM Value = "COMP SYS MGMT"
    7023574256 CNAM Value = "Home Automation"
    Flow route looks these up and places their values in the caller ID which is fine but I would like to add additional Information based on the extension for example
    CNAM Value + SALES
    CNAM Value + John Jones Sales
    etc.
    Is this possible
  5. leejor
    10,737
    280
    You can change any sent name display by entering the corresponding incoming number in the 3CX directory. The name you enter will replace the name sent by your provider. Other than that, ring group and queue, and DID names can be added on to sent name and number. The set display (size) may limit the number of character used. Too many, and characters may get "pushed" off the screen.
    http://www.3cx.com/docs/trunk-management/
