Outbound rule criteria for calls coming via bridge
Discussion in '3CX Phone System - General' started by Edi Kojsi, Dec 28, 2017.
  1. Edi Kojsi
    Nov 28, 2017
    30
    Is it possible to create outbound rule for call coming from other PBX via bridge to make outbound call from this PBX?
    Extension numbers or bridge trunk ID is obviously not working, not possible to create extension group for other PBX extensions as well.
  2. Edi Kojsi
    Nov 28, 2017
    30
    I'm speaking about PBX 'A' outbound rules, PBX 'B' is connected via bridge to PBX 'A'.
    What you point is how to call extension in other PBX via the bridge, or forward the call to other PBX, i.e. from PBX 'B' to PBX 'A'.
    The case is extension from PBX 'B' is making an outbound call, this call passes through the bridge and reaches PBX 'A'. The question is how to differentiate this call (from PBX 'B') into outbound rules of PBX 'A', so to choose specific trunk in PBX 'A' for routing the call out.
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Seems not possible, calls via bridge do not belong to any extension or extension group, so they can be handled only by destination dialed or length. You may add an unique prefix into other PBX outbound rule, thus you will know the call is originated from the other PBX and remove the prefix into main PBX outbound rule.
    Edi Kojsi likes this.
