Outbound rule for FXO2 on GXW4104
Discussion in '3CX Phone System - General' started by ocset, Jan 12, 2013.
  1. ocset
    Jan 12, 2013
    I am new to 3CX and have installed a test system and 3CX has automatically configured my GXW4104 with extensions 10000 - 10003. This is great but when I go to create an outbound rule, there is no option to choose which FXO port to use. I need to configure 3CX to use FXO1 for incoming and FXO2 for outgoing.
    Thanks in advance
    O.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    On the outbound, you can prepend "99X" to the dial stream where X is the line you want the call to use. Assuming no change to the GXW default setting in this regard, the 99 is the command used to indicate "I want this line".
    As far as incoming, I think that will be more a function of what number people dial and should they dial line two, one has to assume that the phone company will send it to the number unless you have invoked some call forwarding at the phone company level.
  3. ocset
    Jan 12, 2013
    Thanks for the quick reply. Will give that a try.
    Regards
    O.
