Outbound Rule Prefix
Discussion in '3CX Phone System - General' started by slynch401k, Mar 2, 2008.
  1. slynch401k
    Jun 29, 2007
    15
    I am having a little difficulty with setting 9 as a prefix for my users to dial out with. I keep getting a "if you want to make a call..." or a busy signal.
    Here's what I have done, under outbound rule I set a 9 for "Calls to Numbers starting with (Prefix)" and then strip 0, or 1 digit under Route 1. If I take out the 9 under "Calls to Numbers starting with (Prefix)" calls go through.
    I also set the "E164 number" under General/General Settings as country - US, Remove if same Country - True, Area Code 703, Remove if same area code - False, we have to dial area code for all numbers in our calling area, and under Add Prefix, I added a 9.
    Can someone post up an example. I have tried many but I am having a problem. I want to have outlook contacts be able to dial out and for users to enter a 9 before calling out.
    Thanks in advance.
    BTW, I just upgraded as we bought another phone system and the quality has improved tremendously since version 3. My grandstream 4108, which I originally thought was a POS works like a charm with my polycom phones. No delay, or echo, so I am now impressed with the advances 3CX has made.
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    242
    try to put the outbound rule the first in line from all your rules. maybe that helps
