Outbound rule with + in callerid
Discussion in 'Windows' started by erike4, Dec 29, 2010.
  1. erike4
    Nov 19, 2010
    13
    In South Africa here (Tanzania, Mozambique and others) the callerid has a "+" rather that the two leading zeros for international calls and local calls (local calls are all prepended with +27 <South African country code> rather than the leading zero). Out providor and I have tried many rules to strip this off but it seems that the "+" make the number skip ruel processing. The reason for this is to return a call without punching in the number and just using the redial button.
  2. erike4
    Nov 19, 2010
    13
    Here is log:
    11:03:17.677 [CM503008]: Call(4): Call is terminated
    11:03:17.671 [CM503023]: Call(4): Call recording is stopped, audio file: D:\Recordings\15\[27123720330]_15-+27123779000_20101229110312(4).wav
    11:03:12.851 Session 240 of leg C:4.1 is confirmed
    11:03:12.732 [CM503007]: Call(4): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=66c5e7bb06784f6f
    11:03:12.726 [CM503007]: Call(4): Device joined: sip:15@192.168.1.100:5060;transport=udp
    11:03:12.725 [CM503022]: Call(4): Call recording is started, audio file: D:\Recordings\15\[27123720330]_15-+27123779000_20101229110312(4).wav
    11:03:12.715 [MS210003] C:4.1:Answer provided. Connection(transcoding mode[unsecure]):192.168.1.250:7006(7007)
    11:03:12.708 [MS210001] C:4.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40610(40611)
    11:03:12.706 Remote SDP is set for legC:4.2
    11:03:12.696 [CM503002]: Call(4): Alerting sip:EndCall@127.0.0.1:40600;rinstance=66c5e7bb06784f6f
    11:03:12.553 [CM503025]: Call(4): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=66c5e7bb06784f6f]
    11:03:12.551 [MS210002] C:4.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7008(7009)
    11:03:12.539 [CM503016]: Call(4): Attempt to reach "+27123779000"<sip:+27123779000@192.168.1.250:5060> failed. Reason: Not Found
    11:03:12.539 [CM503014]: Call(4): No known route to target: "+27123779000"<sip:+27123779000@192.168.1.250:5060>
    11:03:12.523 [CM503010]: Making route(s) to "+27123779000"<sip:+27123779000@192.168.1.250:5060>
    11:03:12.522 [MS210000] C:4.1:Offer received. RTP connection: 192.168.1.100:3000(3001)
    11:03:12.517 Remote SDP is set for legC:4.1
    11:03:12.512 [CM505001]: Ext.15: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Aastra 6731i/2.6.0.2010] PBX contact: [sip:15@192.168.1.250:5060]
    11:03:12.505 [CM503001]: Call(4): Incoming call from Ext.15 to "+27123779000"<sip:+27123779000@192.168.1.250:5060>
    11:03:12.493 [CM500002]: Info on incoming INVITE:
    INVITE sip:+27123779000@192.168.1.250:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bKd593ec15d6e7e8e62.1620e7c61614a75da
    Max-Forwards: 70
    Contact: "27123720330"<sip:15@192.168.1.100:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-1000-8000-00085D29157B>"
    To: "+27123779000"<sip:+27123779000@192.168.1.250:5060>
    From: "27123720330"<sip:15@192.168.1.250:5060>;tag=dfc8d1cfab
    Call-ID: e9f1c2f4c1ca0e78
    CSeq: 14193 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, UPDATE, PRACK, SUBSCRIBE, INFO
    Proxy-Authorization: Digest username="15",realm="3CXPhoneSystem",nonce="414d535c032b8a5095:8d2cbc4f0bca322019e29dcf6f5422d1",uri="sip:+27123779000@192.168.1.250:5060",response="0b35ff946eb572ae18ca8578311c3118",algorithm=MD5
    Supported: gruu, path, timer, 100rel, replaces
    User-Agent: Aastra 6731i/2.6.0.2010
    Allow-Events: talk, hold, conference, LocalModeStatus
    Content-Length: 0
    rule is Numbers starting with prefix = +27 strip=3 prepend=0
