Outbound rule
Discussion in '3CX Phone System - General' started by Anonymous, Oct 25, 2006.
  1. Anonymous
    Anonymous Guest
    I want to route all calls to an external voip line.
    How can i create the rule?
    I have leaved blank in "Calls to Number starting with " and "Calls from extension(s) "...it's wrong?
    When i try to call mobile phones (348....) with sjphone i received this message: 404 Not found
    In status server :
    "Massimiliano"<sip:212@10.1.1.200> <sip:3482338390@10.1.1.200> Call destination cannot be resolved
    Ok,if i call standard phone...why?
    Help!!
    :D
  2. 3CXsupport
    3CXsupport New Member
    3CX Staff
    Aug 21, 2006
    193
    If you simply created a voip line then the PBXServer has automatically created a default rule for you using that provider.
    All you need to do is dial a 0 before the number you wish to call. This will instruct the PBX that it is an extenrnal call. so try:
    03482338390 to reach 3482338390
    Do not hesitate to ask any further questions if you have any problems whatsoever !
  3. Anonymous
    Anonymous Guest
    Is there a way to set up 3cx to not have to dial a prefix? I want the system to work just like a normal phone. I don't want to have to dial 0 or 8 or 9 before the number for external calls.
  4. Anonymous
    Anonymous Guest
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,677
    18
    Prefix required
    A prefix is always required in order for the phone system to know that it is an external number and that it has to use a PSTN or VOIP provider line.
Share This Page
