Outbound rule
Discussion in 'Windows' started by gvsoft, Nov 7, 2016.
  1. gvsoft
    Nov 2, 2016
    31
    How could I make one specific number to use a specific route? I have a GSM Gateway connected to my 3cx. I have made the incoming calls to work but now I want to make a route, every time I ring a number to use my gsm gateway and not my SIP trunk provider.
    Is this possible?
    11,111
    329
    Create a rule specific to the number you want to route to the GSM gateway. Place it above the "general" rule that would normally "handle" that number. Rules are read top to bottom, so the first match will be followed.
  3. gvsoft
    Nov 2, 2016
    31
    How do I make a rule for a specific number?
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
  5. mortenjorge
    Apr 1, 2015
    59
    12
    Prefix: Your Number (ex. 88888888)
    Calls to Numbers with a length of: 8
    Route 1: Your GSM
    Route 2: SIP-trunk (for failover - otherwise you block)
    Then push it to the top, as Complex wrote - 3CX read from top to bottom. and uses first match.
