Outbound rule
Discussion in '3CX Phone System - General' started by daktur, Jan 8, 2018.
  1. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    Hi Guys, a very specific question for outbound rules:
    I want to use 2 different routes, one specifically for mobile phone calls.
    if I set up a rule like:
    XX9* with the length of 9 digit, It will affect all outbound calls that the third dialed number is 9 no matter what the 2 first digits are?
    Thanks!
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,095
    165
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    I don't think you can set a rule like XX9*, unless you create 100 rules, like 009, 019, 029, ... 999 for all numbers starting with XX9.
  4. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    I think the best solution is to set a special prefix when dialing to a mobile phone since on the video, one of the first affirmations is that the outbound rules do not support wildcards.
    Thanks all for the help!
