Outbound Rules stripping more digits
Discussion in 'Ideas' started by jasonhayes, Jan 19, 2017.
Outbound Rules stripping more digits 5 5 7votes
5/5, 7 votes
Increase "Strip Digits" from 9 digits to 15 under Call Rules
  1. Yes - Good Idea
    100.0%
  2. No - Bad Idea
    0 vote(s)
    0.0%
  1. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    10
    Sorry if this has changed in V15. Can under outbound rule "Strip digits" field/function be increased from 9 to at least 11, may be 15. This would aid us replacing expensive numbers dial via 3CX, such as 0845xxxxxxx with an alternative local or new number. We have one support company who our staff dial who have (at last) changed their 0845 number to a 0300 number which is included in our call package, but users still dial the 0845 number. The compnay won't stop the 0845 number as it generates them revenue. I can currently use the "calls to number starting with prefix" to tell it is the 0845xxxxxxx number, but can only strip 9 digits, I need to strip 11, if I could strip all 11, I could then use the prepend field to use the new number. Think this is a real simple request?
  2. solutionsit
    Nov 25, 2014
    62
    5
    This definitely should be changed
  3. leejor
    11,084
    325
  4. AlexDBarrett
    Jan 25, 2011
    71
    9
  5. Jeremy Nelson
    May 12, 2017
    16
  6. TWU
    TWU
    Jan 12, 2016
    18
    Please change the limit from 9 to at least 20 digits!
    This would make it easier for us to route expensive calls to free bridged routes by keeping the dialed extension in the new number.
  7. Brian Buell
    Aug 9, 2017
    36
    5
