Outbound Rules work intermittently
Discussion in '3CX Phone System - General' started by ngnecco, Nov 6, 2009.
  1. ngnecco
    May 14, 2007
    Guys :
    Im having a in inbound directed to a ring and timeout after 10 seconds if no answer. when the no-answer is met then forwarded to an extension which is a forward itself to an outside number. When no extensions in the ring group answer, the incoming call is correctly forwarded to the outside number (via the forward-all-calls setting on the extension).
    Well the thing is, the success rate is about 50%. When the forward doesn´t happen the calling party is hanged upon immediately after the the timeout for no answer happens: Here is the message from the log :
    20:55:41.253 [CM303006]: There's no outbound rule for external number '005411325678978' defined
    The thing is : how could the outbound rule "not be" for some calls and "be" for others. (from the same number, to the same DID)
    Thanks for any help.
    Nelson
  2. south3
    Aug 28, 2009
    15
    Hi!
    We have a similar problem on two installations (latest v8), but we don´t get anything through... When we try to forward external calls to outside numbers we get this error when we try to forward calls from an extension..
    [CM303006]: There's no outbound rule for external number '07353xxxxx' defined
    When we try to forward an active call, we get the following
    10:39:54.480 [CM503016]: Call(102): Attempt to reach <sip:0735xxxxx@10.0.x.x> failed. Reason: Not Found
    10:39:54.480 [CM503014]: Call(102): No known route to target: <sip:0735xxxx@10.0.x.x>
    10:39:54.475 [CM503010]: Making route(s) to <sip:07354xxxx@10.0.x.x>
    10:39:54.474 [CM505003]: Provider:[085xxxxxxx] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [LEICA-1.8.29.1] PBX contact: [sip:085xxxxx@81.x.x.x:5060]
    Best regards,
    Joakim
  3. StefanW
    Jun 2, 2009
    1,199
    79
    how does our outbound rules look like? Do u add the prefix to the nummer u are frwding to?
    why do u frwd to a number and then to an extern phone?
    U can directly frwd to an external number...
  4. south3
    Aug 28, 2009
    15
    Hi Stefan,
    I´m using an outbound rule where I strip 0 digits and allow all extension with numbers 400-498 to dial out.
    I do not add the prefix (tried with cell phone that has an area code). I can directly forward an to a external number.
    Best regards,
    Joakim
