Outbound sip bye problem on one provider
Discussion in '3CX Phone System - General' started by Armandos, Nov 19, 2016.
  1. Armandos
    Nov 19, 2016
    6
    Hello I have setup a 3CX pro on Debian Linux using the 3CX ISO.
    I have 5 sip trunks. 4 of them working perfectly one has the following problem:
    When we do an outbound call and the other party end the call then channel stays up on our end. Speaking with my provider said that when the provider sends SiP bye we reply with error 415 unsupported media type.
    All incoming calls work fine. All other providers work perfectly.
    The trunk uses g codec 711g a law and 711g u law. The registration is IP based. There is no log on activity log of my 3CX.
    Any help would be appreciated
    11,293
    361
    The error message certainly seems to indicate that it is a Codec issue. I would try to limit the Codec selection , for that one provider, to one type. You might have to swap, to see if it make a difference which you choose.
    To see logs associated with the "Bye", you may have to turn on the Verbose logging option to see all messages.
  3. Armandos
    Nov 19, 2016
    6
    Thanks for the reply. tried that as well but no difference. Just enabled verbose logging and will post results tomorrow
  4. Armandos
    Nov 19, 2016
    6
    Hello again,
    below is the Verbose Activity Log from 3CX. Of course I have changed the ip's the names and the numbers THIS IS AN OUTBOUND CALL TO 694XXXXXXX. TOTAL CALL TIME 19 SEC. OTHER PARTY HANG IN 10 SEC. THEN WE TERMINATED THE CALL AT 19TH SECOND. Any help appreciated.
    11/20/2016 1:49:39 AM - L:2.1[Extn] got Terminated Recv Req BYE from 127.0.0.1:5080 tid=Pjktp2RrPrn.M0SfHfXWi.0f0ziAv9Dtmo Call-ID=J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x:
    BYE sip:694XXXXXXXX1@127.0.0.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---Pjktp2RrPrn.M0SfHfXWi.0f0ziAv9Dtmo;rport=5080
    Via: SIP/2.0/UDP 46.198.48.248:51578;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.0-t4i5g3nncgq0wf-zjwumuvttswk9nqaz
    Via: SIP/2.0/TCP 192.168.10.16:50195;rport;branch=z9hG4bKPjktp2RrPrn.M0SfHfXWi.0f0ziAv9Dtmo;alias
    Max-Forwards: 69
    Record-Route: <sip:3cxBridge@127.0.0.1:5080;user=proxy;uri=clnt.0-t4i5g3nncgq0wf-zjwumuvttswk9nqaz>
    To: <sip:694XXXXXXX@XXXXXXXXXX.3cx.eu:5060>;tag=9ea97e1d
    From: "XXXXXXX" <sip:101@XXXXXXX.3cx.eu:5060>;tag=tIV8oiHTchOItaa-4KtUunpdzAQKfq.r
    Call-ID: J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x
    CSeq: 31764 BYE
    User-Agent: 3CXPhone for iPhone 15.2.2.98
    Content-Length: 0
    11/20/2016 1:49:39 AM - L:2.1[Extn] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=Pjktp2RrPrn.M0SfHfXWi.0f0ziAv9Dtmo Call-ID=J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x:
    SIP/2.0 200 OK
    Contact: <sip:694XXXXXX@127.0.0.1:5060>
    To: <sip:694XXXXXXX@XXXXXXX.3cx.eu:5060>;tag=9ea97e1d
    From: "XXXXXXX" <sip:101@XXXXXXXXX.3cx.eu:5060>;tag=tIV8oiHTchOItaa-4KtUunpdzAQKfq.r
    CSeq: 31764 BYE
    Content-Length: 0
    11/20/2016 1:49:20 AM - L:2.1[Extn] got Confirmed Recv Req ACK from 127.0.0.1:5080 tid=Pj7lM2ZBKtjmhfUyTwe6Lk7mCsTD0fIuek Call-ID=J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x:
    ACK sip:694XXXXXXX@127.0.0.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---Pj7lM2ZBKtjmhfUyTwe6Lk7mCsTD0fIuek;rport=5080
    Via: SIP/2.0/TCP 192.168.10.16:50195;rport;branch=z9hG4bKPj7lM2ZBKtjmhfUyTwe6Lk7mCsTD0fIuek;alias
    Max-Forwards: 69
    To: <sip:694XXXXXXX@XXXXXXXXX.3cx.eu:5060>;tag=9ea97e1d
    From: "XXXXXXXXXX" <sip:101@XXXXXXXXX.3cx.eu:5060>;tag=tIV8oiHTchOItaa-4KtUunpdzAQKfq.r
    CSeq: 31763 ACK
    Content-Length: 0
    11/20/2016 1:49:20 AM - L:2.1[Extn] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=PjWYGremciJgBiqQTk4muYcJYbP5AL5V4Y Call-ID=J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x:
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjWYGremciJgBiqQTk4muYcJYbP5AL5V4Y;rport=5080
    Via: SIP/2.0/TCP 192.168.10.16:50195;rport;branch=z9hG4bKPjWYGremciJgBiqQTk4muYcJYbP5AL5V4Y;alias
    Contact: <sip:694XXXXXXX@127.0.0.1:5060>
    From: "XXXXXX"<sip:101@XXXXXXX.3cx.eu:5060>;tag=tIV8oiHTchOItaa-4KtUunpdzAQKfq.r
    CSeq: 31763 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Content-Type: application/sdp
    Supported: replaces
    User-Agent: 3CXPhoneSystem 15.0.59381.0 (59381)
    Content-Length: 273
    v=0
    o=3cxPS 4757655650304000 7689922131525633 IN IP4 127.0.0.1
    s=3cxPS Audio call
    c=IN IP4 127.0.0.1
    t=0 0
    m=audio 7002 RTP/AVP 3 0 8 101
    a=rtpmap:3 GSM/8000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-15
    a=sendrecv
    11/20/2016 1:49:20 AM - L:2.1[Extn] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=PjWYGremciJgBiqQTk4muYcJYbP5AL5V4Y Call-ID=J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x:
    SIP/2.0 200 OK
    Contact: <sip:694XXXXXXXX@127.0.0.1:5060>
    From: "XXXXXX"<sip:101@XXXXXXXX.3cx.eu:5060>;tag=tIV8oiHTchOItaa-4KtUunpdzAQKfq.r
    CSeq: 31763 INVITE
    Supported: replaces
    Content-Length: 273
    v=0
    s=3cxPS Audio call
    c=IN IP4 127.0.0.1
    t=0 0
    a=rtpmap:3 GSM/8000
    a=fmtp:101 0-15
    a=sendrecv
    11/20/2016 1:49:20 AM - L:2.2[Line:10004>>2009230694XXXXXXX] has joined to L:2.1[Extn]
    11/20/2016 1:49:04 AM - L:2.1[Extn] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=PjWYGremciJgBiqQTk4muYcJYbP5AL5V4Y Call-ID=J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x:
    SIP/2.0 180 Ringing
    To: <sip:694XXXXXXX@XXXXXXXX.3cx.eu:5060>;tag=9ea97e1d
    From: "XXXXXXX"<sip:101@XXXXXXX.3cx.eu:5060>;tag=tIV8oiHTchOItaa-4KtUunpdzAQKfq.r
    CSeq: 31763 INVITE
    Content-Length: 0
    11/20/2016 1:49:03 AM - [CM503025]: Call(C:2): Calling T:Line:10004>>2009230694XXXXXXX@[Dev:sip:185.42.XXX.XXX:5060] for L:2.1[Extn]
    11/20/2016 1:49:03 AM - Offer SDP arrived on Leg L:2.1[Extn];
    OnOffer Recv Req INVITE from 127.0.0.1:5080 tid=PjWYGremciJgBiqQTk4muYcJYbP5AL5V4Y Call-ID=J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x:
    INVITE sip:694XXXXXXX@127.0.0.1:5060;transport=UDP SIP/2.0
    Max-Forwards: 69
    Contact: "XXXXXXX" <sip:101@192.168.10.16:50195;transport=TCP;inst="94F566";rinstance=0-t4i5g3nncgq0wf-zjwumuvttswk9nqaz;ob>
    CSeq: 31763 INVITE
    Session-Expires: 1800
    Min-SE: 90
    Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="414d53595830e4ef95:80ca7242f3b368ca3a8f48c2ff71e932",uri="sip:694XXXXXXX@XXXXXXX.3cx.eu:5060",response="57644753cbe717317063665e9f606d8f",algorithm=MD5
    Supported: replaces, 100rel, timer, norefersub
    Content-Length: 363
    v=0
    o=- 3688588144 3688588144 IN IP4 192.168.10.16
    s=pjmedia
    c=IN IP4 127.0.0.1
    b=AS:84
    t=0 0
    a=X-nat:0
    m=audio 11006 RTP/AVP 3 0 8 18 101
    c=IN IP4 127.0.0.1
    b=TIAS:64000
    b=AS:84
    a=sendrecv
    a=rtpmap:3 GSM/8000
    a=rtpmap:18 G729/8000
    a=fmtp:18 annexb=no
    a=fmtp:101 0-15
    11/20/2016 1:49:03 AM - [Flow] Call(C:2): making call from L:2.1[Extn] to T:Line:10004>>2009230694XXXXXX@[Dev:sip:185.42.XXX.XXX:5060]
    11/20/2016 1:49:03 AM - [CM503027]: Call(C:2): From: Extn:101 ("XXXXXXX" <sip:101@XXXXXXX.3cx.eu:5060>) to T:Line:10004>>2009230694XXXXXXX@[Dev:sip:185.42.XXX.XXX:5060]
    11/20/2016 1:49:03 AM - [CM503004]: Call(C:2): Route 1: from L:2.1[Extn] to T:Line:10004>>2009230694XXXXXXX@[Dev:sip:185.42.XXX.XXX:5060]
    11/20/2016 1:49:03 AM - Call(C:2): Call from Extn:101 to 694XXXXXXX matches outbound rule 'Greek Numbers'
    11/20/2016 1:49:03 AM - [Flow] Call(C:2): has built target endpoint: Out#:>>Rule{Greek Numbers}>>69XXXXXXX for call from L:2.1[Extn]
    11/20/2016 1:49:03 AM - [CM503010]: Call(C:2): Making route(s) from Extn:101 to <sip:694XXXXXXX@XXXXXXX.3cx.eu:5060>
    11/20/2016 1:49:03 AM - [CM500002]: Call(C:2): Info on incoming INVITE from Extn:101:
    Invite-IN Recv Req INVITE from 127.0.0.1:5080 tid=PjWYGremciJgBiqQTk4muYcJYbP5AL5V4Y Call-ID=J0TAzP9choMC.GVJfLH8VPCkkXnSFR0x:
    INVITE sip:694XXXXXX@127.0.0.1:5060;transport=UDP SIP/2.0
    Max-Forwards: 69
    Contact: "XXXXXX" <sip:101@192.168.10.16:50195;transport=TCP;inst="94F566";rinstance=0-t4i5g3nncgq0wf-zjwumuvttswk9nqaz;ob>
    From: "XXXXXXXXX"<sip:101@tXXXXXXXX.3cx.eu:5060>;tag=tIV8oiHTchOItaa-4KtUunpdzAQKfq.r
    CSeq: 31763 INVITE
    Min-SE: 90
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="414d53595830e4ef95:80ca7242f3b368ca3a8f48c2ff71e932",uri="sip:694XXXXXXXX@XXXXXXX.3cx.eu:5060",response="57644753cbe717317063665e9f606d8f",algorithm=MD5
    Content-Length: 363
    v=0
    s=pjmedia
    c=IN IP4 127.0.0.1
    b=AS:84
    t=0 0
    a=X-nat:0
    c=IN IP4 127.0.0.1
    b=TIAS:64000
    b=AS:84
    a=sendrecv
    a=rtpmap:3 GSM/8000
    a=fmtp:18 annexb=no
    a=fmtp:101 0-15
    11/20/2016 1:49:03 AM - [CM503001]: Call(C:2): Incoming call from Extn:101 to <sip:694XXXXXXX1@XXXXXXX.3cx.eu:5060>
    11/20/2016 1:48:02 AM - L:1.1[Extn] got Terminated Recv Req CANCEL from 127.0.0.1:5080 tid=PjaL-evFVZ5903lUvhJdHAS3miN49EyGBo Call-ID=7BrWu1oDZMrwwFZ8qs00O4TSIEwPF7a1:
    CANCEL sip:694XXXXXXX@127.0.0.1:5060;transport=UDP SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjaL-evFVZ5903lUvhJdHAS3miN49EyGBo;rport=5080
    Via: SIP/2.0/TCP 192.168.10.16:50195;rport;branch=z9hG4bKPjaL-evFVZ5903lUvhJdHAS3miN49EyGBo;alias
    Max-Forwards: 69
    From: "XXXXXX" <sip:101@XXXXXXXX.3cx.eu:5060>;tag=T96PwNHFs4AMSsamUQsJucIl9XLy3d5b
    Call-ID: 7BrWu1oDZMrwwFZ8qs00O4TSIEwPF7a1
    CSeq: 7221 CANCEL
    Content-Length: 0
    11/20/2016 1:48:02 AM - L:1.1[Extn] Sending: OnSendResp Send 487/INVITE from 0.0.0.0:0 tid=PjaL-evFVZ5903lUvhJdHAS3miN49EyGBo Call-ID=7BrWu1oDZMrwwFZ8qs00O4TSIEwPF7a1:
    SIP/2.0 487 Request Terminated
    To: <sip:694XXXXXX@XXXXXX.3cx.eu:5060>;tag=77f37020
    From: "XXXXXXX"<sip:101@XXXXXXXX.3cx.eu:5060>;tag=T96PwNHFs4AMSsamUQsJucIl9XLy3d5b
    CSeq: 7221 INVITE
    Content-Length: 0
    11/20/2016 1:48:02 AM - L:1.1[Extn] Sending: OnSendResp Send 200/CANCEL from 0.0.0.0:0 tid=PjaL-evFVZ5903lUvhJdHAS3miN49EyGBo Call-ID=7BrWu1oDZMrwwFZ8qs00O4TSIEwPF7a1:
    SIP/2.0 200 OK
    To: <sip:694XXXXXXX@XXXXXXXX.3cx.eu:5060>;tag=77f37020
    From: "XXXXXXXXX" <sip:101@XXXXXXXXX.3cx.eu:5060>;tag=T96PwNHFs4AMSsamUQsJucIl9XLy3d5b
    CSeq: 7221 CANCEL
    Content-Length: 0
    11/20/2016 1:47:59 AM - L:1.1[Extn] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=PjaL-evFVZ5903lUvhJdHAS3miN49EyGBo Call-ID=7BrWu1oDZMrwwFZ8qs00O4TSIEwPF7a1:
    SIP/2.0 180 Ringing
    To: <sip:694XXXXXXX@XXXXXXX.3cx.eu:5060>;tag=77f37020
    From: "XXXXXXXX"<sip:101@XXXXXXXXX.3cx.eu:5060>;tag=T96PwNHFs4AMSsamUQsJucIl9XLy3d5b
    CSeq: 7221 INVITE
    Content-Length: 0
    11/20/2016 1:47:59 AM - [CM503025]: Call(C:1): Calling T:Line:10004>>2009230694XXXXXXX@[Dev:sip:185.42.XXX.XXX:5060] for L:1.1[Extn]
    11/20/2016 1:47:59 AM - [Flow] Call(C:1): making call from L:1.1[Extn] to T:Line:10004>>2009230694XXXXXX@[Dev:sip:185.42.XXX.XXX:5060]
    11/20/2016 1:47:59 AM - [CM503027]: Call(C:1): From: Extn:101 ("XXXXXXX" <sip:101@XXXXXXX.3cx.eu:5060>) to T:Line:10004>>2009230694XXXXXXX@[Dev:sip:185.42.XXX.XXX:5060]
    11/20/2016 1:47:59 AM - [CM503004]: Call(C:1): Route 1: from L:1.1[Extn] to T:Line:10004>>2009230694XXXXXX@[Dev:sip:185.42.XXX.XXX:5060]
    11/20/2016 1:47:59 AM - Call(C:1): Call from Extn:101 to 694XXXXXX matches outbound rule 'Greek Numbers'
    11/20/2016 1:47:59 AM - [Flow] Call(C:1): has built target endpoint: Out#:>>Rule{Greek Numbers}>>694XXXXXX for call from L:1.1[Extn]
    11/20/2016 1:47:59 AM - [CM503010]: Call(C:1): Making route(s) from Extn:101 to <sip:694XXXXXXX@XXXXXXXX.3cx.eu:5060>
    11/20/2016 1:47:59 AM - [CM500002]: Call(C:1): Info on incoming INVITE from Extn:101:
    Invite-IN Recv Req INVITE from 127.0.0.1:5080 tid=PjaL-evFVZ5903lUvhJdHAS3miN49EyGBo Call-ID=7BrWu1oDZMrwwFZ8qs00O4TSIEwPF7a1:
    Max-Forwards: 69
    From: "XXXXXX"<sip:101@XXXXXXX.3cx.eu:5060>;tag=T96PwNHFs4AMSsamUQsJucIl9XLy3d5b
    CSeq: 7221 INVITE
    Min-SE: 90
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="414d53595830e4ae26:0f060fbdbf8cbb31bccb12ced46a7906",uri="sip:69XXXXXX@XXXXXXX.3cx.eu:5060",response="f6ed4452ecd864d6423cbf38205604f9",algorithm=MD5
    Content-Length: 363
    v=0
    o=- 3688588079 3688588079 IN IP4 192.168.10.16
    s=pjmedia
    c=IN IP4 127.0.0.1
    b=AS:84
    t=0 0
    a=X-nat:0
    m=audio 11002 RTP/AVP 3 0 8 18 101
    c=IN IP4 127.0.0.1
    b=TIAS:64000
    b=AS:84
    a=sendrecv
    a=rtpmap:3 GSM/8000
    a=fmtp:18 annexb=no
    a=fmtp:101 0-15
    11/20/2016 1:47:59 AM - [CM503001]: Call(C:1): Incoming call from Extn:101 to <sip:694XXXXXX@XXXXXX.3cx.eu:5060>
  5. Armandos
    Nov 19, 2016
    6
    Tried one more thing to exclude a bug.
    Temporary I moved the installation to windows to check if there would be any difference. Unfortunately the problem was exactly the same. So LINUX distribution is not the problem.
