Outbound sound only
Discussion in '3CX Phone System - General' started by spuddie82, May 13, 2016.
  1. spuddie82
    May 13, 2016
    Hi everyone
    Really hoping you can help. Have just set up a new 3cx server and system in a new office in Poland. We currently already have 2 in the UK and 1 in the USA. All are connected fine with internal calls. However with external calls we can dial out and the call connects but no sound comes through. Sound at the receivers end can be heard.
    Also we can't receive calls in either. Speaking to the phone supplier his latest suggestion is:
    Could you change the settings so that 3CX sends messages Options using the SIP protocol, because the PABX sends UDP currently.
    However, I cannot locate where to change this, can anyone help with any ideas? We are using version 14.
    Thanks in advance
    Paul
    10,586
    252
    This is usually caused by incorrect settings in the local router, or firewall, that is blocking the ports used for audio.
    If you list the make/model of router you are using, perhaps someone that also uses that same model can comment on what need to be checked.
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    To check if this is a Firewall issue, you could always run the Firewall Checker found in the Management Console:
    http://www.3cx.com/blog/docs/firewall-checker/
    I would recommend first getting this passing everything before going any further.
    Note: Don't forget to manually restart the 3CX Services after running the Firewall Checker.
