Outbound Transfers and calls not working
Discussion in '3CX Phone System - General' started by rmorock, May 22, 2010.
  1. rmorock
    May 22, 2010
    5
    I am using Broadvoice VOIP - Heres my problem:
    1. Call in to the system, system answers
    2, press 9, that goes to 8004
    3, 8004 transfers to external number
    4. When the system tries to make the transfer and fails. Says the number its busy (its not busy)
    5, the log shows that there is no Outbound Rule for the dialed number. When I have a rule made.
    Here is my log
    Code:
    02:28:28.984  [CM503016]: Call(15): Attempt to reach <sip:8004@127.0.0.1:5060> failed. Reason: Busy
    02:28:28.984  [CM303006]: There's no outbound rule for external number '18882299490' defined
    02:28:28.984  [CM503010]: Making route(s) to <sip:8004@127.0.0.1:5060>
    Any help that you guys can provide, I would like so much.
    Roy Morock
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Roy,
    Welcome to the forum
    Log says
    You must create an outbound rule to allow the call to be sent out of the PBX, it is not matching any at this point.
  3. rmorock
    May 22, 2010
    5
    How do I do that? I have an outbound rule setup
    Thanks,
    Roy
  4. leejor
    10,362
    226
    How do you dial outside numbers? 1888xxxxxxx or 91888xxxxxxx? If you normally dial a 9 first then make sure that the number has been entered in that way as the forwarded number. Also make sure that the extension is allowed to transfer to external numbers.
  5. rmorock
    May 22, 2010
    5
    I prefer to just dial 1, (ac) then any number
    How would I set the OutBound rule, and where is the option.
  6. leejor
    10,362
    226
    The outbound rule would be built in "Outbound Rules". Can you dial the toll free number from another extension, at this point, and have the call go through? Did you not originally create a rule for all 1+10 digit numbers?
  7. rmorock
    May 22, 2010
    5
    Attached is a screenshot...
    • What am I missing, I even at one point had 8,9,10 in the number leigth
      Also How do I make it where all extentions have the right to transfer
  8. leejor
    10,362
    226
    If you include the areacode in all numbers then they aren't seven digits long are they? I would suggest rethinking the "Calls to numbers with a length of" field.
    You do have more than one trunk to allow an outside incoming call to go back out, right?
