- Joined
- May 2, 2008
- Messages
- 2
- Reaction score
- 0
Hi Gurus,
I hope you guys can help me out..
I tested 3CX pabx about 1 months ago, and it all works, with internal and external calls plus receiving.
So I decided to deploy it for home.
The strange thing is everything is still configured the same way, but just doesnt work anymore with outbound.
I got 2 internal soft phones (100, 101) to my 2 pc, and a single server for pabx with all the antivirus and firewall disabled.
for voip, I have iinet voip account which is tested and works fine with soft phone, as well as an ATA.
now.. pls keep in mind that I have tested about 1 month ago and it was all working..
here is my test configurations
100 <=> 101 (works fine)
external => 100 (rule based ) works fine
however, when I call to an outside number it will not work. the busy light for the internal lit up, but will not pickup the voip line to dial out.
on the server status page, it will just say, it is dailing.. and will not hook to the voip line.
so.. i tried dailing from my mobile to the voip number and it shows that the line status busy.. and then route to my internal 100 handset.
So.. i believe the problem with 3cx not passing the initiating sequence to my voip (external) line.
I have restarted the server, using cmd script, as well as trying on 5060 and 5061.
the worst thing is it was working about 1 mnths ago.
HELP HELP HELP
Thanks for any support / idea / strong coffees that you guys can send my way.
Cheers
ps: here is my LOG
Time Function Message
10:40:38.312 Call::Terminate [CM503008]: Call(4): Call is terminated
10:40:06.390 MediaServerReporting::SetRemoteParty [MS210002] C:4.2:Offer provided. Connection(transcoding mode): 123.243.14.101:5064(5065)
10:40:06.093 CallCtrl:nSelectRouteReq [CM503004]: Call(4): Calling: VoIPline:150@[Dev:sip:[email protected]:5060]
10:40:05.703 CallCtrl:nSelectRouteReq [CM503010]: Making route(s) to [sip:[email protected]]
10:40:05.703 MediaServerReporting::SetRemoteParty [MS210000] C:4.1:Offer received. RTP connection: 5.75.28.116:8000(8001)
10:40:05.703 CallLeg::setRemoteSdp Remote SDP is set for legC:4.1
10:40:05.703 Extension:rintEndpointInfo [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NCH Swift Sound Express Talk 3.08] Transport: [sip:5.96.236.48:5060]
10:40:05.687 CallCtrl:nIncomingCall [CM503001]: Call(4): Incoming call from Ext.100 to [sip:[email protected]]
10:40:05.578 CallLeg:nNewCall [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 5.75.28.116:5061;rport=5061;branch=z9hG4bK43697344
Max-Forwards: 20
Contact: [sip:[email protected]:5061]
To: [sip:[email protected]]
Call-ID: [email protected]
CSeq: 892 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, INFO, REFER, NOTIFY
Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="12854335205:e15dc12e20840c6856d50d897c1f7fc4",uri="sip:[email protected]",response="786e3479fd84f4ae6c83d4b263b779f5",opaque="",algorithm=MD5
Supported: replaces
User-Agent: NCH Swift Sound Express Talk 3.08
Content-Length: 0
HELP HELP HELP
Cheers
ps: here is my LOG
Max-Forwards: 20
CSeq: 892 INVITE
Supported: replaces
Content-Length: 0
