Outbound VOIP Line problem
Discussion in '3CX Phone System - General' started by scarborough, Jan 30, 2008.
  1. scarborough
    Jan 28, 2008
    I set my VOIP Line using pfingo and tried to dial to a PSTN tel, but failed, below is the log, pls help thanks
    23:57:08.281 Call::RouteFailed [CM503014]: Call(14): Attempt to reach [sip:09682112@192.168.1.64:5060] failed. Reason: No Answer
    23:57:08.281 CallLeg::eek:nFailure [CM503003]: Call(14): Call to sip:9682112@sip.pfingo.com:5060 has failed; Cause: 408 Request Timeout; internal
    23:56:35.796 CallLeg::eek:nFailure [CM503003]: Call(14): Call to sip:9682112@sip.pfingo.com:5060 has failed; Cause: 408 Request Timeout; internal
    23:56:03.812 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(14): Calling: VoIPline:10001@[Dev:sip:31273389@sip.pfingo.com:5060]
    23:56:03.531 MediaServerReporting::STUN [MS101003] C:14.2: Possible firewall problem. Address mapping failed on STUN server 64.69.76.23:3478 for local address ":9000"
    23:56:02.515 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(14): Calling: VoIPline:10000@[Dev:sip:31277229@sip.pfingo.com:5060]
