Outbout Calls
Discussion in '3CX Phone System - General' started by javf, Sep 10, 2011.
  1. javf
    Sep 10, 2011
    I have just switched to 3CX from TrixBox and cant get outbound calls to work over Vitality trunk.
    Here is a copy of the server log.....
    Call to 1973xxxxxxx@(Ln.10000@Vitelity) has failed. [ V4 64.2.142.108:5060 UDP target domain=unspecified mFlowKey=784 ] replied: 503 Service Unavailable; from IP:64.2.142.108:5060
    Thank you for your help.
    11,129
    330
    What URL do you have specified in your trunk settings? It is usually something like sipX.vitelity.net, where X= the number of the server you were told to use. Setup for this provider was very simple, no issues at all.
  3. javf
    Sep 10, 2011
    thank you for your response, I do have sip#@vitelity.net defined in the config.
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Edit the voip trunk, under the Advanced tab, make sure you have "Require Registration for" set to "Outbound Calls"
  5. leejor
    11,129
    330
    I use Vitelity for international LD, and unless you have incoming service from them, you do not need to register. It won't hurt, but it is not necessary.
