outgoing call domain
Discussion in 'Android' started by OwenBurnett, Aug 24, 2011.
  1. OwenBurnett
    Aug 24, 2011
    11
    when i try to call from a client using the dyndns domain of the 3cx server it gives me an error message
    21:24:32.188 [CM503013]: Call(15): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 110@x.dyndns.org:5060 tid=xxxxxx.HRHAN cseq=INVITE contact=140@10.70.x.x:5060 / 4930 from(wire)
    when its the local lan domain it works, how can i specify in teh 3cx android client a domain to be used for the call ID but different form the server domain actually connecting to?
  2. StefanW
    Jun 2, 2009
    1,216
    88
    The IP for external connection can not be. this is an internal IP i guess u have set the phone wrong up.
    Also 3CX does not give any support on non static IP server. 10.70.x.x:5060
  3. OwenBurnett
    Aug 24, 2011
    11
    the second ip adress is one of my ISP not form my lan, i messed that up when removing personal informations (like exact ip or exact host name)
    so it should have been:
    [CM503013]: Call(15): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 110@x.dyndns.org:5060 tid=xxxxxx.HRHAN cseq=INVITE contact=140@178.x.x.x:5060 / 4930 from(wire)
  4. leejor
    10,758
    286
    Put your dyndns "name"(x.dyndns.org) in the domain name space, in 3CX (PBX)
    At least, I think, that's what you are trying to achieve.
  5. OwenBurnett
    Aug 24, 2011
    11
    great, but , where is the option, I cant find it :/
  6. leejor
    10,758
    286
    It's in the advanced settings, left hand column of 3CX.
