Outgoing call problem [CM503013]
Discussion in '3CX Phone System - General' started by OwenBurnett, Aug 24, 2011.
  1. OwenBurnett
    Aug 24, 2011
    11
    when trying to call from the internet over 3cx i get the following error:
    21:24:32.188 [CM503013]: Call(15): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 110@x.dyndns.org:5060 tid=xxxxxx.HRHAN cseq=INVITE contact=140@10.70.x.x:5060 / 4930 from(wire)
    I assume the problem ist that it wants a number @x.dyndns.org, can i somehow tell it to always assume @localhost?
    also can i somehow change in the 3cx android client the @domain ?
  2. willow
    willow Member
    Mar 1, 2011
    471
    it must match on both sides or the 3cx will reject the call.
  3. OwenBurnett
    Aug 24, 2011
    11
    in my lan I use domains xxx.local while from outisd ethe router pc is accressible through dyndns with xxx.dyndns.org
    how can I make it match?
