Outgoing Caller ID
jjwerkman
Is it possible to sent the internal registration number with the call when the call is transfered to my cellphone? So, I can see on my cellphone that the call is made from my internal organization?
Possibly, it depends to a large extent as to how/who your carriage/provider is. You did not indicate. in any event, it is less likely if you are using PSTN carriage as most of the carriers use the caller-id associated to the account and ignore the system generated one (at least in the US).
Get 3CX - Absolutely Free!
3CX
