Outgoing calls Forbidden
Discussion in '3CX Phone System - General' started by Pandl, Sep 8, 2010.
  1. Pandl
    Sep 7, 2010
    Everything was working well untill I installed the 3cx systems upgrade. Now I keep getting the forbidden message when trying to phone to an outside number. Have tried with my service provider but no luck
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Can you post some logs so we can see what the system is saying?
  3. leejor
    11,285
    360
    Are they not co-operating with you or ?? They should be able to tell you why the calls are "forbidden". I'm assuming that the trunk(s) are registering properly. Are you sure that you are sending the correct digits?
