Outgoing calls - patton 4552
Discussion in '3CX Phone System - General' started by hasler, Jan 14, 2009.
  1. hasler
    Jan 7, 2009
    20
    Hi.
    I'm new to 3cx.
    Actually I have installed the latest 3cx version an connected successfully the connected the patton 4552 R5.2 2008-11-14 SIP
    Incomings calls work but i can't make any outgoing call.
    I created an outgoing rule for the Patton 4552, but I had no luck with this.
    Here the log from an outgoing call
    13:25:52.206 [CM503008]: Call(37): Call is terminated
    13:25:52.175 [CM503015]: Call(37): Attempt to reach <sip:0474412104@192.168.1.3:5060> failed. Reason: Not Found
    13:25:52.160 [CM503004]: Call(37): Calling: Unknown:mad:[Dev]
    13:25:52.160 [CM503010]: Making route(s) to <sip:0474412104@192.168.1.3:5060>
    13:25:52.160 [CM505001]: Ext.10: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4184.0] Transport: [sip:192.168.1.3:5060]
    13:25:52.113 [CM503001]: Call(37): Incoming call from Ext.10 to <sip:0474412104@192.168.1.3:5060>
    13:25:52.113 [MS003005] C:37.1: Failed to create Endpoint: (destination=192.168.1.116)
    EndPoint: ID=00000036@(LOCAL)
    LOGID=C:37.1 Status: MSEP_FAILED
    RTP:192.168.1.3:7072
    RTCP:192.168.1.3:7073
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Party RTCP:0.0.0.0:0
    Decoders:
    <empty>
    13:25:52.113 [MS003002] C:37.1: RTP socket 192.168.1.3:7072 binding failed with error code 10048
    13:25:52.050 [CM500002]: Info on incoming INVITE:
    INVITE sip:0474412104@192.168.1.3:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.116:5070;branch=z9hG4bK-d8754z-c448d3348732c27e-1---d8754z-;rport=5070
    Max-Forwards: 70
    Contact: <sip:10@192.168.1.116:5070>
    To: <sip:0474412104@192.168.1.3:5060>
    From: "3CXPhone"<sip:10@192.168.1.3:5060>;tag=923d7963
    Call-ID: YjFlZWU2MTA1MGVhYWNmNWEzMTJkNWE5ZDI2NmU4NDc.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="12876409551:39618de23dada391a18cfea858d1bd52",uri="sip:0474412104@192.168.1.3:5060",response="67dfef8912d63c864a7e78a431a0f950",algorithm=MD5
    Supported: replaces
    User-Agent: 3CX Phone 7.0.4184.0
    Content-Length: 0
    Can you help me to resolve the problem.
    Thanks,
    Andreas
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    The problem is that the media is failing to bind due to some other application. Do you have DNS server running on this machine?
    Please check this article to see how to resolve the issue http://www.3cx.com/support/media-server.html
    regards
  3. hasler
    Jan 7, 2009
    20
    yes i have a DNS Server running on the machine (SBS 2003 server).
    I will install the 3cx phone system on a new pc with Windows XP to test.
    Thanks,
    Andreas
  4. hasler
    Jan 7, 2009
    20
    I now installed the 3cx phone system to a xp pro machine.
    I regenerated the config file for the patton 4552 with the wizzard an imported it to the patton.
    The patton is registred in the 3cx (green led).
    I tried to make an outgoing call but the problem remains:
    22:09:20.108 [CM503008]: Call(2): Call is terminated
    22:09:20.108 [CM503015]: Call(2): Attempt to reach <sip:0474412104@192.168.1.10:5060> failed. Reason: Not Found
    22:09:20.093 [CM503004]: Call(2): Calling: Unknown:mad:[Dev]
    22:09:20.093 [CM503010]: Making route(s) to <sip:0474412104@192.168.1.10:5060>
    22:09:20.077 [CM505001]: Ext.11: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4184.0] Transport: [sip:192.168.1.10:5060]
    22:09:20.062 [CM503001]: Call(2): Incoming call from Ext.11 to <sip:0474412104@192.168.1.10:5060>
    Can somebody help me to resolve the problem.
    Thanks,
    Andreas
  5. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Can you please enable Verbose mode and paste the full INVITE and the relative logging that shows the routing of the call.
    Please ensure you have setup your outbound rule correctly.
  6. hasler
    Jan 7, 2009
    20
    Hi I can't set the verobse mode???
    I set the verbose mode and restarted the services but the the loggin mode remains on "medium"
    Thanks,
    Andreas
  7. alexmallia
    3CX Support
    Aug 4, 2008
    130
    Go to the list of users of this machine and set the user ASPNET is set to be a member of the administrators group. After doing this restart IIS admin service, Reload the 3CX configuration, enable verbose and then restart the 3CX services.
    regards
  8. hasler
    Jan 7, 2009
    20
    Thanks, no it worked.
    Here the outgoing call with verbose set:
    11:51:07.643 [CM503008]: Call(3): Call is terminated
    11:51:07.628 [CM503015]: Call(3): Attempt to reach <sip:10@192.168.1.10:5060> failed. Reason: Not Registered
    11:51:07.628 [CM503016]: Call(3): Target is not registered: Ext:Ext.10
    11:51:07.612 [CM503010]: Making route(s) to <sip:10@192.168.1.10:5060>
    11:51:07.612 [MS210000] C:3.1:Offer received. RTP connection: 192.168.1.4:4874(4875)
    11:51:07.612 Remote SDP is set for legC:3.1
    11:51:07.596 [CM503001]: Call(3): Incoming call from 472843166@(Ln.10000@4552) to <sip:10@192.168.1.10:5060>
    11:51:07.534 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:10
    11:51:07.503 Looking for inbound target: called=474412104; caller=472843166
    11:51:07.472 [CM500002]: Info on incoming INVITE:
    INVITE sip:10000@192.168.1.10 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.4:5060;branch=z9hG4bKb823542e1
    Max-Forwards: 70
    Route: <sip:192.168.1.10;lr>
    Contact: <sip:472843166@192.168.1.4:5060>
    To: <sip:474412104@192.168.1.10>
    From: <sip:472843166@192.168.1.10>;tag=acfbc8e6937a320
    Call-ID: 7a0d11c055b13a136b0ad170b7ddd12c@192.168.1.10
    CSeq: 1314180523 INVITE
    Proxy-Authorization: Digest response="908597589eeac4900c8043ab9e1a5be4",username="10000",realm="3CXPhoneSystem",nonce="12876576667:159351244346fc827a7d01a281f62594",algorithm=MD5,uri="sip:10000@192.168.1.10"
    Supported: timer, replaces
    User-Agent: Patton SN4552 2BIS EUI MxSF v3.2.8.45 00A0BA043F63 R4.2 2007-09-19 SIP
    Content-Length: 0
    Remote-Party-ID: <sip:474412104@192.168.1.10>;party=called
    Thanks for your help,
    Andreas
  9. hasler
    Jan 7, 2009
    20
    i trierd to change the outgoing rule.
    Now i do not get the error "not found", but the call doesn't go trough.
    In the log i get the following info.
    The number i call is normally reachable trough ISDN line.
    16:08:57.263 [CM503008]: Call(9): Call is terminated
    16:08:57.247 [CM503015]: Call(9): Attempt to reach <sip:0474410881@192.168.1.10;user=phone> failed. Reason: No Answer
    16:08:57.247 [CM503003]: Call(9): Call to sip:0474410881@192.168.1.4:5060 has failed; Cause: 408 Request Timeout; internal
    16:08:25.031 [MS210006] C:9.2:Offer provided. Connection(by pass mode): 192.168.1.13:59414(59415)
    16:08:25.015 [CM503004]: Call(9): Calling: Unknown:0474410881@(Ln.10000@4552)@[Dev:sip:10000@192.168.1.4:5060]
    16:08:25.000 [CM503010]: Making route(s) to <sip:0474410881@192.168.1.10;user=phone>
    16:08:25.000 [MS210000] C:9.1:Offer received. RTP connection: 192.168.1.13:59414(59415)
    16:08:25.000 Remote SDP is set for legC:9.1
    16:08:25.000 [CM505001]: Ext.12: Device info: Device Identified: [Man: Snom;Mod: 8xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom820/8.0.12] Transport: [sip:192.168.1.10:5060]
    16:08:24.984 [CM503001]: Call(9): Incoming call from Ext.12 to <sip:0474410881@192.168.1.10;user=phone>
    16:08:24.968 [CM500002]: Info on incoming INVITE:
    INVITE sip:0474410881@192.168.1.10;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.13:1025;branch=z9hG4bK-4eonpm3ixfux;rport=1024
    Max-Forwards: 70
    Contact: <sip:12@192.168.1.13:1025;line=p9b3o201>;reg-id=1
    To: <sip:0474410881@192.168.1.10;user=phone>
    From: "Büro TC"<sip:12@192.168.1.10>;tag=jo0ou8lqym
    Call-ID: 3c26e2db7452-puwhcelh49xi
    CSeq: 2 INVITE
    Session-Expires: 3600;refresher=uas
    Min-SE: 90
    Accept: application/sdp
    Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO
    Proxy-Authorization: Digest username="12",realm="3CXPhoneSystem",nonce="12876592104:a71b6ccb8fd1fff78e73bc4a5d41635c",uri="sip:0474410881@192.168.1.10;user=phone",response="103e481931ece41ccace87636787383c",algorithm=MD5
    Supported: timer, 100rel, replaces, from-change
    User-Agent: snom820/8.0.12
    Allow-Events: talk, hold, refer, call-info
    Content-Length: 0
    P-Key-Flags: resolution="31x13", keys="4"
    Thanks,
    Andreas
