Outgoing calls say forbidden on softphone
Discussion in '3CX Phone System - General' started by rgittings, Sep 20, 2013.
  1. rgittings
    Sep 20, 2013
    I am trying to make external calls from the softphone and it says forbidden, I know the sip info is correct, because I can actually connect sometimes , but never disconnect and reconnect right away.
    10,368
    229
    If you are using the phone with the 3CX PBX, there should be something in the PBX log indicating, or , at least giving a clue to, the problem
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    You say that external calls fail.. how about dialing to voicemail or an internal extension?
    That would split the problem "handset to PBX" from "PBX to trunk".
    If internals work.. less likely a config problem on the softphone.
