Outgoing Calls SPA3000
Discussion in '3CX Phone System - General' started by jfrederick, Dec 7, 2009.
  1. jfrederick
    Dec 7, 2009
    19
    I just installed the 3CX software and configured the SPA-3000 Gateway. I Can receive incoming calls but i cant place and calls on that line. It says destination not found. I dont know what else to try some one help please. The Log Is Below.
    10:04:54.296 [CM503020]: Normal call termination. Reason: Not found
    10:04:54.296 [CM503016]: Call(37): Attempt to reach <sip:18882784437@192.168.1.2:5060> failed. Reason: Not Found
    10:04:54.296 [CM503014]: Call(37): No known route to target: <sip:18882784437@192.168.1.2:5060>
    10:04:54.281 [CM503010]: Making route(s) to <sip:18882784437@192.168.1.2:5060>
    10:04:54.281 [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 4.0.9878.0] PBX contact: [sip:101@192.168.1.2:5060]
    10:04:54.281 [CM503001]: Call(37): Incoming call from Ext.101 to <sip:18882784437@192.168.1.2:5060>
    Thank You For your help
  2. bblokey
    Apr 15, 2008
    57
    Did you create the outbound line and set a rule to use it?
  3. jfrederick
    Dec 7, 2009
    19
    A rule like? Another thing i want to know. I am in the caribbean and our code is 264 and i want to make a call do i have to put 1 264 everytime. Thanks for your help
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Depends on your provider. Analog lines and PRI lines usually don't need to use the area code. SIP trunks usually do need the entire phone number.
  5. leejor
    11,133
    331
    If you want to make any sort of outside calls you have to create an Outbound Rule to tell 3CX where to send the call and how, if required, to manipulate the digits. Since this is a gateway you should already know if your local PSTN provider requires you to dial 1 264 on each call. You can strip off, or add on, any required digits in an outbound rule. if you are only required to dial 7 digits for a local call then you can create a rule that has you dial 9+xxxxxxx, stip off the first digit and send the remaining out on the trunk group you created for the SPA3000.
  6. rodster
    Aug 19, 2009
    13
    I'm not sure with SPA3000 but the SPA 3102, the default port is 5061 and not 5060. Check the port settings on the SPA3000
  7. leejor
    11,133
    331
    As i recall (and i could be wrong) the default ports are the same in both the 3000 and 3102, 5060 for the LINE and 5061 for the PSTN. the 3CX documentation mentions using 5062, for some reason. As long as the ports are set the same at both ends and everything else is set correctly, it should work.
  8. jmodi
    Apr 24, 2009
    5
    If you can receive calls, that means SPA3000 is correctly configured and routing calls to extension under Line. According to the log, the call that originated from ext 101 to 18882784437 could not be completed because there was no defined route.
    Add a rule like in Outgoing Calls,
    Calls beginning with 1
    Action:
    Route through SPA3000,
    Prefix: strip 0, add 0. (You can play with this, but if there is something missing, the call will not be routed).
    Good luck.
    Joe
  9. leejor
    11,133
    331
    Since you've chosen to number your extensions beginning with 1, if i were you I would require a 9 before any outgoing calls. This will give you a bit more flexibility in the future and avoid conflicts with the internal numbering plan.
