outgoing calls
Discussion in '3CX Phone System - General' started by xhp, Mar 1, 2011.
  1. xhp
    xhp
    Mar 1, 2011
    I'm new to VoIP an 3CX PBX so please excuse me if my following question is stupid, but unfortunately I still can't solve it.
    I successfully installed and configured 3CX PBX on xp machine in small network behind NAT and firewall. I can make a calls in my network between softphones and ip phones without problems, but I'd also like to be able to make a call to another networks.
    I have several testing SIP accounts on iptel.org, so I want to reach them.
    As the pc with 3CX is behind firewall I set up rules as suggested, firewall checker shows, that it is OK.
    I don't have any IP provider yet - I'm not sure if I can make an outgoing call without it.
    Could please anyone give me an advice how to get outgoing calls working?
    regards
    Jan
    10,360
    224
    You would add trunks, in 3CX to link to this provider.
    What do you mean by this? You don't have high speed internet? If not, then , no, you won't be able to establish a connection with any VoIP provider.
  3. xhp
    xhp
    Mar 1, 2011
    Thanks for answer.
    I have added a generic trunk connected with one of my accounts on iptel.org.
    Now I'm trying to make call from local phone to 160787@iptel.org, still no succes.
    Code:
    12:01:19.386  [CM503020]: Normal call termination. Reason: Not found
    12:01:19.386  [CM503016]: Call(1): Attempt to reach <sip:160787@iptel.org> failed. Reason: Not Found
    12:01:19.386  [CM503014]: Call(1): No known route to target: <sip:160787@iptel.org>
    12:01:19.386  [CM503010]: Making route(s) to <sip:160787@iptel.org>
    12:01:19.386  [CM505001]: Ext.103: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [wxCommunicator] PBX contact: [sip:103@127.0.0.1:5060]
    12:01:19.386  [CM503001]: Call(1): Incoming call from Ext.103 to <sip:160787@iptel.org>
    12:00:51.587  [CM504001]: Ext.103: new contact is registered. Contact(s): [sip:103@192.168.240.97:5061/103]
    12:00:51.383  [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.240.97:5061/100]
    12:00:27.788  [CM504002]: Ext.100: a contact is unregistered. Contact(s): []
    11:59:52.004  [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.240.97:5061/100]
    11:59:45.691  [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:IVRForward@127.0.0.1:40600;rinstance=94913f1d6b83459e/IVRForward]
    11:59:45.691  [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:EndCall@127.0.0.1:40600;rinstance=aa8157dc609d23c2/EndCall]
    11:59:45.691  [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600;rinstance=b5f6d2dcd7a275cc/999]
    11:59:38.315  [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=9d82da354d613f0a/*1]
    11:59:38.315  [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=50389449b0c8b1b3/*0]
    11:59:38.206  [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*777@127.0.0.1:40000;rinstance=7d9fe1f44b2bf8a1/*777]
    11:59:36.503  IP(s) added:[192.168.240.97]
    11:59:34.393  [CM504008]: Fax Service: registered as sip:888@192.168.240.97:5060 with contact sip:888@192.168.240.97:5100;user=phone
    11:59:34.143  [EC200006]: Conference server is connected:    application:pohanka-pc:0/3CXConferenceRoom    local:127.0.0.1:5482    remote:127.0.0.1:6553
    11:59:32.643  [EC200004]: IVR server is connected:    application:pohanka-pc:0/IVRServer    local:127.0.0.1:5482    remote:127.0.0.1:6549
    11:59:31.362  [EC200002]: Media server is connected:    application:pohanka-pc:0/MediaServer    local:127.0.0.1:5482    remote:127.0.0.1:6548
    11:59:30.877  [EC200005]: Parking Orbit server is connected:    application:pohanka-pc:0/3CXParkOrbit    local:127.0.0.1:5482    remote:127.0.0.1:6547
    11:59:30.533  [EC100007]: External application is connected:    application:pohanka-pc:0/QueueManager    local:127.0.0.1:5482    remote:127.0.0.1:6546
    11:59:28.096  [CM506002]: Resolved SIP external IP:port (194.228.143.170:5060) on Transport 192.168.240.97:5060
    11:59:27.893  [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.240.97:5060
    11:59:27.721  [CM504002]: Ext.100: a contact is unregistered. Contact(s): []
    11:59:26.439  Failed to obtain short path name for [C:\Documents and Settings\All Users\Data aplikacĂ­\3CX\Bin\Cert]
    11:59:26.439  [CM501002]: Version: 9.0.15776.0
    11:59:25.502  [EC200001]: Configuration server is connected:    application:pohanka-pc:5485/DBProvider    local:127.0.0.1:6533    remote:127.0.0.1:5485
    11:59:25.439  [CM501010]: License Info: Load Failed
    I meant VoIP provider/trunk in 3CX
  4. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    You dont have an outbound rule for 3cx to know where to route the call
    you can set one up with a mask for iptel.org or one for a 7 digit number and route it through the provider. Then it should work
    There is no "default" outbound route in 3cx so you have to set them up.
