outgoing calls
Discussion in '3CX Phone System - General' started by GBond, Nov 30, 2011.
  1. GBond
    Nov 27, 2011
    12
    22:48:16.481 [CM503020]: Normal call termination. Reason: Not found
    22:48:16.481 [CM503016]: Call(42): Attempt to reach <sip:01234123456@192.168.1.6:5060> failed. Reason: Not Found
    22:48:16.481 [CM503014]: Call(42): No known route to target: <sip:01234123456@192.168.1.6:5060>
    22:48:16.481 [CM503010]: Making route(s) to <sip:01234123456@192.168.1.6:5060>
    22:48:16.481 [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:105@192.168.1.6:5060]
    22:48:16.481 [CM503001]: Call(42): Incoming call from Ext.105 to <sip:01234123456@192.168.1.6:5060>
    Can any tell me what I am doing wrong with the out going call (every thing else appears to work ok including incoming calls)
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    What is 192.168.1.6 ?
    If this is address of your 3CX server, you don't have outgoing route to a provider.
    Regards
  3. GBond
    Nov 27, 2011
    12
    This has helped me to resolved this issue
  4. Angela M
    Oct 28, 2011
    Im also having this issue, Inbound calls work but outbound calls dont( with the logs showing the same error as the OP's) Ive set up the VoIP provider according to all the guides floating around(and the Outbound rules) could someone please help?
  5. leejor
    10,779
    286
    Please post the 3CX log of a failed call, as the originator of this post did. It is very difficult to diagnose a problem without something more to go on.
