Outgoing Line Priority
Discussion in '3CX Phone System - General' started by mdmattingly, May 5, 2011.
  1. mdmattingly
    May 5, 2011
    We are running the 3cx phone system with a Patton Smartnode 4110 gateway. When we place a phone call, it uses the fourth line on the gateway first and the hunts back to the first one if that is taken. Is there a way for us to configure either the gateway itself or the 3cx software so that it dials out on the first port instead of the last one when no other lines are in use? The last one is also the fax number so we would rather leave that free as much as possible without shutting off outgoing calls on it all together.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Not used the Patton Smartnode 4110 gateway as of yet, but do you have the option to set each line with its own username and password, if so, you could seperate them and then apply outbound rules within 3CX
