Outgoing line problem
Discussion in '3CX Phone System - General' started by George Georgiou, Nov 15, 2007.
  1. George Georgiou
    Jul 21, 2007
    22
    I have connected two SPA-3102 On 3cx free version (Bridge) with two PSTN lines each one of them. The incoming lines are OK work fine both of them simultaneously. I have problem with outgoing lines I can use only one line from the first gateway. How can I define the second line. I am using Linksys phone SPA-942. Please advice
  2. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    If you edit your Outboand Call Rule you can define the prefix the extensions will use to get from your first VOIP Gateway and inside that rule you have an option that says Backup rule where you can define your second VOIP Gateway.
    Hope that can help you.
  3. George Georgiou
    Jul 21, 2007
    22
    AldoLinares
    I define the backup getway but still the same problem, find here below error massage
    CM104008] Call(47): Call from Ext.101 to 99450852 terminated; cause: 503 Service Unavailable; from IP:192.168.10.3
  4. iang
    Nov 18, 2007
    13
    Hi George
    Does the problem still occur if "Make outbound calls on" is set to "Any gateway"?
