Resolve
New User
- Joined
- Sep 19, 2007
- Messages
- 94
- Reaction score
- 0
We've got a patton 4114 connected to 3 analogue lines.
At the moment we can only make 1 outgoing call - otherwise we're busied out:-
0:51:28.293 Call::RouteFailed [CM503014]: Call(80): Attempt to reach [sip:[email protected]:5060] failed. Reason: Busy
10:51:28.293 CallLeg:nFailure [CM503003]: Call(80): Call to sip:[email protected]:5060 has failed; Cause: 486 Busy Here; from IP:192.168.1.3
10:51:28.090 CallLeg:nFailure [CM503003]: Call(80): Call to sip:[email protected]:5060 has failed; Cause: 486 Busy Here; from IP:192.168.1.3
10:51:27.918 CallLeg:nFailure [CM503003]: Call(80): Call to sip:[email protected]:5060 has failed; Cause: 486 Busy Here; from IP:192.168.1.3
10:51:27.762 CallCtrl:nSelectRouteReq [CM503004]: Call(80): Calling: PSTNline:10001@[Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060]
10:51:27.700 CallCtrl:nIncomingCall [CM503001]: Call(80): Incoming call from Ext.120 to [sip:[email protected]:5060]
Apart from the one line that really is busy (showing yellow) the other lines show as green.
Any clues ?
Tim
Any clues ?
Tim
