Outgoing Problems
Discussion in '3CX Phone System - General' started by bluefox8080, Feb 7, 2008.
  1. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    I suddenly got this error with an incoining call on a Grandstram GXW4104:
    22:30:15.250 Call::Terminate [CM503008]: Call(14): Call is terminated
    22:30:15.218 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10004 forwards to DN:203
    22:30:04.000 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(14): Calling: Ext:203@[Dev:sip:203@172.16.0.130:2048;line=j7hb9sbr]
    22:30:04.000 Line::printEndpointInfo [CM505002]: Gateway:[Grandstream] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:7) 1.0.0.55] Transport: [sip:172.16.3.10:5060]
    Why does it say: Device Not Identified: even though the call does come in?
    When I try to phone out via that GW I get:
    22:34:33.468 Call::Terminate [CM503008]: Call(15): Call is terminated
    22:34:33.437 Call::RouteFailed [CM503014]: Call(15): Attempt to reach [sip:00829205716@172.16.3.10;user=phone] failed. Reason: Server Failure
    22:34:33.437 CallLeg::eek:nFailure [CM503003]: Call(15): Call to sip:0829205716@172.16.3.20:5060 has failed; Cause: 503 Service Unavailable; from IP:172.16.3.20:5060
    22:34:33.359 CallLeg::eek:nFailure [CM503003]: Call(15): Call to sip:0829205716@172.16.3.20:5060 has failed; Cause: 503 Service Unavailable; from IP:172.16.3.20:5060
    22:34:33.296 CallLeg::eek:nFailure [CM503003]: Call(15): Call to sip:0829205716@172.16.3.20:5060 has failed; Cause: 503 Service Unavailable; from IP:172.16.3.20:5060
    22:34:33.234 CallLeg::eek:nFailure [CM503003]: Call(15): Call to sip:0829205716@172.16.3.20:5060 has failed; Cause: 503 Service Unavailable; from IP:172.16.3.20:5060
    22:34:33.171 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(15): Calling: PSTNline:10002@[Dev:sip:10002@172.16.3.20:5060, Dev:sip:10003@172.16.3.20:5062, Dev:sip:10004@172.16.3.20:5064, Dev:sip:10005@172.16.3.20:5066]
    22:34:33.140 CallCtrl::eek:nIncomingCall [CM503001]: Call(15): Incoming call from Ext.210 to [sip:00829205716@172.16.3.10;user=phone]
    Why would this be?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    'Device not identified' means that there's no capabilities settings for that device defined on your system. It means only that default capabilities will be applied.
    Re outbound call: it seems GW can not dial specified number (0829205716). Check its dialplan and regional settings for land-lines (some countries have (physically) different ways of going off-hook, dialling and hanging up). It is possible that your GW just can not go off-hook.
  3. bluefox8080
    Oct 28, 2007
    181
    Thank you for the reply,
    I just identified the problem is with the Telco Provider. They have intermittent promlems on their network:-(
