- Joined
- Sep 8, 2006
- Messages
- 51
- Reaction score
- 0
My system is pc running XP connected to Ethernet port on my Linksys SPA-3102. The SPA internet port is connected to my Netgear router. Netgear to my internet service provider. My phone is connected to the phone port on the SPA then the SPA to the wall.
It’s looking quite good all my lights on the 3cx are green and the phone can call all my soft phones and also make outgoing calls using my voip providers. Incoming calls from both voip and pstn ring all phones and work fine.
So the problem, if I try to phone out using pstn line the phone dials beep beep beep and so on. Then I get an engaged tone.
The server status said “has failed; cause: 404 not found; from ip (and it gives the SPA-3102 IP)
Any ideas
Ps... I should add my outgoing rule is set to 9 for pstn and the log does show the 9 being striped
Any ideas
