Outgoing rule is not handled correctly
Discussion in '3CX Phone System - General' started by 3cxisti, Feb 18, 2013.
  1. 3cxisti
    Dec 11, 2012
    24
    I have a outgoing rule für mobile number beginning with "+" (eg. +49179....)
    If I call this number the outgoing rule is not mached and the call is not forwarded to the correct trunk.
    What can be the reason?
    This is my outgoing rule:
    +49151,+49152,+49157,+49159,+49160,+49162,+49163,+49170,+49171,+49172,+49173,+49174,+49175,+49176,+49177,+49178,+49179
    On the top of the rule-list. It is set that the first "+" must be cut and repleaced by "00".
    I see in the log, that the number is received correctly "+49179" but sent false "+49179". The reason is the a later rule matches which formats the number on a false way.
    Has somebody already had such troubles with correct but not matching rules?
    Thank you...
    I.
  2. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    This blog explains the outbound rules in good detail please go to this link and follow the instructions. it should help you set up your rules correctly http://www.3cx.com/blog/voip-howto/outbound-rules-a-complete-example/
  3. Roman.Stryuk
    Jan 15, 2015
    Hi 3cxisti,
    Have you found some solution for this problem? As far as the article mentioned above does not provide any example for the numbers leaded with "+".
    Thanks!
  4. leejor
    10,758
    286
    I believe it has to do with the implementation of E164.
    have a look over this... http://www.3cx.com/forums/outbound-rules-with-solved-16569.html#p84305
