Outlook 2007 / 3cx ver7 / Tapi
rico06
Is ther anybody has the command to have outlook popup the contact when ther is incoming call ?
You will need some external application to do this. Look at tapicall.com
ok but you should have it in a futur version
I tried tapicall and another one and it was not very efficient, problem with the format of phone number...
Try taking a look at what SNOM have done with their Flexor CTI software...
works great!
Take a look at this: http://www.3cx.com/blog/releases/outlook-salesforce-integration-beta/
Please Send an E-mail to [email protected] if you find any problems with it.
That way we can fix it on the spot if there are any problems.
Getting Started - Admin
NickWinker
Get 3CX - Absolutely Free!
3CX
