Outlook 2010 - TAPI Driver or Plug-in?
Discussion in '3CX Phone System - General' started by activeserve, Aug 6, 2010.
  1. activeserve
    Jun 29, 2009
    25
    I'm wondering if the Outlook 2010 CRM calling integration feature will be a TAPI Driver or a Plug-in (similar to the Terminal Services version of the 3CX Call Assistant)?
    Does anyone know when the final version will be released? :|
    Thanks!
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    We are going to release a Beta Version of the 2010 Plugin, in a few weeks / month, but there is no ETA for the Terminal Services part of the TAPI. I think that part is going to take a while.
  3. switch2asp
    Feb 27, 2008
    8
    I think that quite a lot of people are waiting for support of Outlook 2010 (x64)
    Is there a way to trace the progress of that? Are you guys maybe posting updates of the progress or so?
    Wish you guys a lot of succes and that it may be released SOON :p
    Kind regards,
    Rene
