Outlook 2010
Discussion in '3CX Phone System - General' started by xotj123, May 23, 2010.
  1. xotj123
    May 21, 2010
    I am running Outlook 2010 64 Bit edition. The 3CX Assistance is not compatible, and not working.
    Regards,
    TJ Havens
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Office 2010 is still in beta stage at this point. It will be supported in the next release of the assistant.
  3. dab
    dab
    Nov 1, 2009
    67
    Sorry but Office 2010 is RTM and available for developers, partneres, etc. since april 22th.
    And there are no significant changes since the last beta.
    Please fix it and make us happy :)
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi TJ Havens,
    Yes this will be added with the latest release of version 9. We will add a new add-in to migrate with Outlook 2010. Outlook made new changes which will need a new add-in / plugin to work.
    Thanks and Regards
