Outlook Add In runtime error
Discussion in 'CRM / Helpdesk / App Integration' started by JackH, Aug 22, 2017.
  1. JackH
    Aug 4, 2017
    7
    I've noticed this happening on a few machines periodically. It initially installed OK but this morning, for example, I have the following error on a 2 PC's
    I have tried restarting Outlook and trying to manually re enable the add in but this error pops up every time
    [​IMG]
    The full Error details
    Code:
    Name:
    From: file:///C:/ProgramData/3CXPhone for Windows/PhoneApp/DotNetScripts/Outlook/References/3CXOutlookAddin.vsto
    ************** Exception Text **************
    System.Deployment.Application.DeploymentDownloadException: Downloading file:///C:/ProgramData/3CXPhone for Windows/PhoneApp/DotNetScripts/Outlook/References/3CXOutlookAddin.vsto did not succeed. ---> System.Net.WebException: Could not find a part of the path 'C:\ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts\Outlook\References\3CXOutlookAddin.vsto'. ---> System.Net.WebException: Could not find a part of the path 'C:\ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts\Outlook\References\3CXOutlookAddin.vsto'. ---> System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts\Outlook\References\3CXOutlookAddin.vsto'.
       at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
       at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
       at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
       at System.Net.FileWebStream..ctor(FileWebRequest request, String path, FileMode mode, FileAccess access, FileShare sharing, Int32 length, Boolean async)
       at System.Net.FileWebResponse..ctor(FileWebRequest request, Uri uri, FileAccess access, Boolean asyncHint)
       --- End of inner exception stack trace ---
       at System.Net.FileWebRequest.GetResponseCallback(Object state)
       at System.Net.FileWebRequest.EndGetResponse(IAsyncResult asyncResult)
       at System.Net.FileWebRequest.GetResponse()
       at System.Deployment.Application.SystemNetDownloader.DownloadSingleFile(DownloadQueueItem next)
       at Microsoft.VisualStudio.Tools.Applications.Deployment.ClickOnceAddInDeploymentManager.GetManifests(TimeSpan timeout)
       at Microsoft.VisualStudio.Tools.Applications.Deployment.ClickOnceAddInDeploymentManager.InstallAddIn()
  2. Andreas Paradisiotis
    Apr 7, 2017
    53
    12
