Outlook dialer
Discussion in '3CX Phone System - General' started by iamgreen, Sep 25, 2007.
  1. iamgreen
    Sep 25, 2007
    52
    I was reading in the marketing materials for 3cx PBX that is it possible to dial a contact from Outlook. I can't seem to find in the technical documentation how to set this up. Can anyone give me a hint? :)
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    You may be asking about Exchange 2007 integration http://www.3cx.com/support/exchange-server-2007.html available only in the Enterprise Edition http://http://www.3cx.com/phone-system/edition-comparison.html. To the best of my knowledge this is the only method of direct integration between 3CX and Outlook type features.
    Of course if all you are seeking is the ability to dial numbers directly from within Outlook Contacts, you are seeking eyeBeam Softphone http://www.counterpath.com/eyebeam-features.html paid version, not X-Lite. This softphone integrates with Outlook, installs a button on the Contact card, allowing you to dial Outlook numbers via the softphone (that runs on 3CX).
  3. iamgreen
    Sep 25, 2007
    52
    Wahooo
    It looks like an I answered my own guestion. There is a little click2dial enabler that I can download from
    http://www.enum.at/SIP-TAPI.479.0.html?&L=9
    I installed this on my desktop computer, configured it, and POW. I am able to open a contact in Outlook and click the dial button. It works like MAGIC.
    -Johnny
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Guess you could do that too :eek:
    Never thought of that since I already had eyeBeam. Works OK? Easy setup?
  5. iamgreen
    Sep 25, 2007
    52
    Yeah, it works like a top.
    Open Outlook and find a contact that you want to call. Click the call Button and select which contact number you want to use.
    Your phone will ring, answer it and you will hear your hold music while the session is setup, then you are calling out. It's pretty kewl.
    -Johnny
  6. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Works Like a charm... Thks :p
    Cheers
  7. iamgreen
    Sep 25, 2007
    52
    I might add, that I recently discovered that the new version of the 3CX VOIP client has a TAPI dialer built into it. Just open the control panel, Phone/Modem Applet and make sure that the 3CX client is listed. Then you can dial from Outlook. I quit using the Enum SipTapi. The new 3CX client has a smoother version of click2dial that uses the MAKECALL function rather than simple call bridging. It works great.
  8. iamgreen
    Sep 25, 2007
    52
    Haven't had that problem. We are still working on the ATA not dialing the number right.
  9. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    thanks for the tips, this work great
    cheers
  10. Lori
    Apr 15, 2008
    Re: Wahooo
    Have installed the dialer, it rings but it does not dial. Apparently the problem is my ATA (Netcom V100) What ATA are you using?
    Lori
  11. iamgreen
    Sep 25, 2007
    52
    I am using the Grandstream 4104 (suxors) but I am not sure that is the problem. Did you go into the options for SipTapi and assign the servername and ext?
