Outlook Email Signatures
Discussion in 'CRM / Helpdesk / App Integration' started by Sean Williams, Nov 6, 2017.
  1. Sean Williams
    Nov 6, 2017
    14
    Is it possible to turn outlook email signatures into clickable phone numbers? (like the Chrome click to call plugin)
  2. Andreas Paradisiotis
    Apr 7, 2017
    53
    12
    No this is not possible. You can post this into ideas section
