Outlook Integration With V12
Discussion in '3CX Phone System - General' started by accelerated, Sep 5, 2013.
  1. accelerated
    Jul 26, 2013
    10
    Is there a new download or procedure to integrate the new Windows 3CX phone application with Outlook? Outlook integration came included in the old MyPhone application in V11. This is for a Win7 Pro desktop environment with Office 2010.
    Thanks,
    Felix Perez Jr
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Outlook was grouped in the "CRM Integration Module" which is now a separately-priced add-on product.. oh the joy when I get to inform clients who love that feature.
    I personally don't care.. but they will..
  3. accelerated
    Jul 26, 2013
    10
    That's going to be fun.....All my clients including us love that feature and we used it daily.
  4. ian.watts
    Apr 8, 2011
    532
    Though they haven't updated the "CRM Integration Module" on the split modules: http://www.3cx.com/ordering/pricing/modules/
    Perhaps the trend is it will be about $50 USD/user I would guess?.. Good luck with that.
  5. DJHiP
    Dec 2, 2009
    29
    To regain Outlook Connectivity with the new 3CXPhonev12 app in windows you need to install the desktop CRM component.
    This isn't the Priced CRM Addon for the Server side, so its at no cost.
    If you navigate to the recent blog post: http://www.3cx.com/blog/myphone/crm-integration/ you can find the Version 12 download.
    This will install the client side Outlook integration and will bring the 'Dial from Outlook' functionality back.
    I've found it to be a little buggy, but its better than the nothing the default application brings.
    I feel like 3CX are doing great things with the change, but it all feels a little premature and under-tested for my liking. :|
  6. accelerated
    Jul 26, 2013
    10
    Thanks DJHiP! That's exactly what I was looking for. It is a bit buggy, it has been useless on two computers so far.
  7. accelerated
    Jul 26, 2013
    10
    Just to update.....Got the integration to work on all computers, had to redo the install and make sure Outlook and the 3CX Windows app were shutdown completely.
    Working fine so far.
    Thanks again DJHiP!
  8. DJHiP
    Dec 2, 2009
    29
    No Problems :)
