OUTLOOK PAUSE DIALING
Discussion in '3CX Phone System - General' started by dimitripapa, Feb 19, 2013.
  1. dimitripapa
    Feb 19, 2013
    IS IT POSSIBLE TO Add a pause in a dialed number for access an extension USING OUTLOOK?
    11,115
    329
    Any pause in SIP dialling has to be doable from the device doing the dialling. While some analogue phones attached to an ATA are capable of this, most other devices usually aren't. The problem with inserting a pause is that there must be some way to tell the device to "send these digits, up to this point, now", then wait, and SIP doesn't work that way. All digits are sent as a complete package.
    So, I'm thinking that the answer is going to be , no.
