Outlook plugin not working
Discussion in 'CRM / Helpdesk / App Integration' started by JackH, Aug 14, 2017.
  1. JackH
    Aug 4, 2017
    7
    Two separate issues:
    Windows 7 / Outlook 2010
    1. Already had the Outlook integration working on one PC. However since updating 3CX to the latest version (could be coincidence) when I right-click a contact, the option to "Call contact with 3CX" is greyed out and cannot be clicked.
    Windows 10 / Outlook 2013
    2. On another PC that was already set up with the same extension/account as of that above, I notice that the 3CX Outlook plugin had not automatically been installed on this machine, nor had I been prompted by it when opening Outlook. When I go to Advanced Settings > Integration from the 3CX client I get a csc.exe application error - unable to start correctly.
    Followed by another error "Error loading script from folder 'DotNetScripts\Outlook': Could not find file C:\Users\XXXX\AppData\Local\Temp\qx2hzozh.dll".
    Edit: After installing the latest Win10 updates the second problem has resolved itself.
    #1 JackH, Aug 14, 2017
