Outside call in to paging
Discussion in '3CX Phone System - General' started by leejor, Jul 2, 2015.
  1. leejor
    11,291
    361
    What you are looking for is a DISA trunk with PIN authentication. Unfortunately 3CX doesn't do that. In the past I've used a SPA3102. You have to go from analogue to SIP, or vice versa. It also handles authentication via caller ID as well. They have been discontinued but can still be found.
    11,291
    361
    If you need any help in setting it up, let me know.
