Outside the local network
Discussion in '3CX Phone System - General' started by thour, May 11, 2009.
  1. thour
    Nov 15, 2008
    16
    Hello!
    After a long time i did fix my PAP2 outside the office, but i can recive calls but i cant not talk just hear the other person. Everything works fine in local network but when i'am home i cant talk just hearing the other person. Cant dial out. What can be the problem?
  2. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    What is your Port Forwarding looking like? Im not sure what your PAP2 situation was, so I have no idea if this has been covered. One way audio tends to be related to audio getting stripped due to the Proper Audio Range not being opened about 90 percent of the time.
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    you need :
    use stun server
    forward the rtp ports
    you can test with dmz if it works so you need forward rtp ports only
  4. thour
    Nov 15, 2008
    16
    i have the server by dmz is that enough? should the pap2 be in dmz at my home network to?
  5. thour
    Nov 15, 2008
    16
    in the office router or the home router? witch port?
  6. galal202
    galal202 New Member
    Jun 23, 2008
    235
    test with dmz in both sides
    also use stun in both sides
    the rtp ports in linksys from 16384 to 16482
  7. thour
    Nov 15, 2008
    16
    when i changed it to 16482 it was no audio at all. When i changed the pap2 to dmz i did get a internal ip number 192.168.1.1
    On the server side i have a dlink di-624
  8. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello ,
    in rtp you need 8 ports
    ex: 16400:16407
    did you test stun server?
  9. ciscotech2007
    Jan 27, 2009
    94
    Is your PAP2 unlocked from vonage?
    backup your settings and start your config. from scratch. Balance the PSTN lines with the voltage.
    http:/ /www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE (3102 is similar)
  10. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Papt not like spa3102 and has not pstn line
    it is 2 fxs ports only
    can set to 2 different servers or providers
  11. thour
    Nov 15, 2008
    16
    how can i configurate my di-624? why cant i talk only hear the other person.
  12. thour
    Nov 15, 2008
    16
  13. thour
    Nov 15, 2008
    16
    Hello !
    Why is the wrong? This is what it standing when i'am trying to call out from another place outside my office. I can recive calls but they cant hear me and i cant dial number.
    (see the picture) can somebody help me to config my pap2t?
      File size:
      147.7 KB
      1,435
  14. leejor
    10,360
    226
    So... the PAP2T is at the "remote" location, I assume. Will it work properly if it is NOT behind the router there? in other words,set for DHCP and picks up a public Ip and not an IP from the router? If you are going to use the PAP2T behind the router then you have to give it a fixed IP and then make sure that all ports are forwarded to that IP. The ports are all listed in the 3CX documentation. A lot of routers will forward the ports for you as not everyone has access to the router at the remote end. There is no other VoIP device assigned to port 5060 at the remote end is there?
  15. amygoda
    amygoda Member
    Sep 18, 2006
    436
    You have to set the stun server and nat to yes
