OVH VPS VPN
Discussion in '3CX Phone System - General' started by Philip Darnell, Oct 11, 2017.
  1. Philip Darnell
    Philip Darnell New Member
    Jan 26, 2017
    132
    10
    Has anyone using an OVH VPS server managed to setup a VPN to the server?
    I don't know if it is even possible but would possibly be a route I could look at going over STUN or SBC.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    I don't think this is possible, more over 3CX don't recommends installing VPN software on the same host as PBX.
    Philip Darnell likes this.
  3. Philip Darnell
    Jan 26, 2017
    132
    10
    Thanks for the reply.
  4. StefanW
    Jun 2, 2009
    1,199
    79
    I would like to correct "3CX don't recommends installing VPN software on the same host as PBX", correct would be dont install VPN software within 3CX PBX hosts!
    In OVH the way would be using vRACK and then firewall routing service: https://www.ovh.de/dedicated_server/firewall_vpn_virtual_rack.xml . In google cloud this would work just as a software config of the cloud in the VPC services...
  5. Philip Darnell
    Jan 26, 2017
    132
    10
    Thanks for the reply Stefan, So the Vrack is an additional service on top of the VPS?
    So Google Cloud has the ability to do this included in the server price?
    Would it be possible to then set this VPN upto link to a Draytek 2860 router?
  6. StefanW
    Jun 2, 2009
    1,199
    79
