Page All returning busy signal
Discussion in '3CX Phone System - General' started by jrm1010, Feb 27, 2013.
  1. jrm1010
    Feb 27, 2013
    Not sure what happened but our page all function is not working, it rings, we hear the beep then the person attempting the page gets a busy signal and it hangs up. Any thoughts on what might be the issue here?
    thanks
    11,101
    329
    Have a look over the 3CX log, it should show what is happening, and may point you in the direction of a solution. If this just began, I would think that it is the result of some change in programming, or perhaps, set firmware?
