Page an audio message
Discussion in '3CX Phone System - General' started by gschrijvers, May 23, 2014.
  1. gschrijvers
    May 23, 2014
    We use the page function in 3CX to clear the building in case of a fire.
    We'd like to connect a page number (group page) to a prerecorded audio message.
    Is this possible?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    Maybe not thru 3cx - but using multicast paging and VLC stream.
  3. leejor
    11,277
    360
    This came up a while ago, and i seem to recall that it was to do with paging announcements in a school. There was a link to an after market product designed to work with 3CX. If you do some searches of the forum you should come across it (if that sounds like a route you would want to go).
