Page/Intercom feature
Discussion in '3CX Phone System - General' started by hainesk967, Feb 26, 2013.
  1. hainesk967
    May 23, 2011
    38
    I have 3CX v11 and some SPA504G and SPA514G phones and I am trying to get the paging/intercom feature to work. When I dial *9 and the extension (i.e. *9200) the phone wants me to set a call forward. When I disable the call forward feature in the phone, it then just gives me an invalid number error after only dialing *92. The built in paging feature in the SPA504G is set as *96. When I use this (i.e. *96200), the other extension does not auto answer to the speaker phone like I'm hoping and instead rings and rings as if I simply dialed their extension, despite auto answer being enabled in the phone preferences. Any ideas?
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    First Question - Is your 3CX system licensed, or just running unlicensed demo mode???
    (As *9 Paging is not enabled in an un-licensed version 11 3CX ).
    Use the demo key at the bottom of this article to license/enable all 3CX features (but it will only give you 2 simultaneous calls):
    http://www.3cx.com/blog/releases/3cx-phone-system-v11-service-pack-4/
    In regard to the built-in paging feature ... this is only applicable if the phone is running off a Cisco-Linksys VoIP PBX. When putting the SPA phones on a 3CX, you can delete all of those 'vertical Service Activation Codes' - as they won't do a thing for you!
    Best regards ...
  3. hainesk967
    May 23, 2011
    38
    Thanks for the reply.
    My 3CX is licensed (8 calls).
    How do I delete the 'vertical Service Activation Codes' so I can use the 3CX paging feature? I looked around the phone settings and couldn't find anything.
  4. 3CXfoxhallsolutions
    Sep 8, 2012
    211
    Delete the Vertical Service Activation Codes [VSAC] on the SPA, by browsing the IP address of the phone, then logging on as 'admin' ...
    Click the 'Advanced' link (top right).
    Select the 'Regional' tab
    Scroll half-way down to the VSAC section
    Remove every code in that section ...
    I now use Yealink phones in my installs - so have not put work into figuring out how I can clear this section using a modified provisioning template ...
  5. hainesk967
    May 23, 2011
    38
    Do I need to modify the dial plan so that my phone will allow me to dial the *9[ext] number?
  6. hainesk967
    May 23, 2011
    38
    Ok, so I went to the ext page and modified the dialing plan from:
    (*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
    to this:
    (*xxxx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
    And I think it's working. I will have to test it later to see as I only have one phone here right now.
  7. 3CXfoxhallsolutions
    Sep 8, 2012
    211
    Woops ... No ... It looks like you are flying blind here ...
    Have a look at this guide which shows what you need to do, to manually configure an SPA phone as a 3CX extension.
    http://www.3cx.com/sip-phones/ Updated link
    In fact, you should be able to make the phone auto-provision ... http://www.3cx.com/sip-phones/Cisco-SPA/ ... and then just use the manual notes to check the settings.
    You won't need to do a fancy dial-plan mod' as all a 3CX extension needs as a dial-plan entry is ...
    [x*].
    This is a cover-all dial-plan, which then makes it possible to use outbound dialing rules in the 3CX system to guide calls if any further routing is needed.
