Paging and iOS App
Discussion in '3CX Phone System - General' started by roadwings, Jul 21, 2016.
  1. roadwings
    May 16, 2015
    49
    14
    When I page, extensions that are registered with the iOS app get a pushed notification for a call, and then a missed call for a page. Can this be disabled? Paging should probably not go to the iOS app at all.
  2. tratz
    tratz New Member
    Oct 21, 2015
    109
    15
    IOS App is a SIP client. Depending on how you do paging, if it is direct the system should send the call to the phone. If using multicast, then the IOS app should ignore it unless it is on the same network as the multicast paging.
    --Tracy
