Paging hang up leaves page on hold/in limbo
Discussion in '3CX Phone System - General' started by Bronston Hansen, Oct 10, 2018 at 8:20 PM.
  1. Bronston Hansen
    Jul 24, 2018
    14
    I have a group all in one location (same subnet) all on Grandstream GXP1780s. I have a paging group set up for them accessible with a custom speed dial blf.
    Occasionally after they use the paging and hang up their phone it acts like the paging was put on hold or somehow disconnected from the phone but the page is still active. When that happens it ties up pretty much every phone in the group until I drop the call from the receptionist client.
    Does anyone have any ideas what is happening or why and most importantly how to fix it?
    For bonus points can you tell me how to reduce the delay after they hit the paging blf? It takes up to 10 seconds for the page to start. I mention this because I'm wondering if both issues are related.
    Thanks,
    Bronston
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,326
    448
    Hello @Bronston Hansen
    How many extensions are in the same group and are you using multicast group or a paging group?
    If you are familiar with wireshark you could run a capture and see if the paging is terminated properly or not and if the delay is with the PBX or somewhere in the network.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    I find Paging Groups are good for about 10-15 phones at the most. After that there is a lot of overhead created opening a connection to every single phone.
    Best bet is to use Multicast Paging instead... however, I have seen folks get transferred into Multicast paging and suddenly you hear "hello, hello" of the loudspeakers with no way to retrieve the call.
